Retired_Member's avatar
Retired_Member
Jul 03, 2017
Change MTU size on XS728T
The manual says I can change the MTU size, but I dont see (in the GUI) the setting to change at Switching > Ports > Port Configuration.   Model Name XS728T Boot Version 1.0.0.0 Software Version 6.5...
  • ElaineP's avatar
    Jul 03, 2017
    Hi gcarson,
    Welcome to NETGEAR community!
    The L2 Jumbo Frames size cannot be changed for XS728T, which default value should be 10240 byte frame size under Switching.
    But the L3 ipv4 MTU can be changed under Routing>IP>IP Configuration, the default value is 1500.
    NETGEAR Employee
ProSupport for Business
