JeffAtK2
Jul 19, 2022Guide
Changing Default Gateway on GS752, SX748, and M4300
Hi, We're changing out our gateway this weekend and setting up the new one with a different IP address (same subnet). Anyone know of any gotchas on changing these on managed switches? Any flushin...
DaneA
Aug 07, 2022NETGEAR Employee Retired
Since you are changing your default gateway, I think you need to double check or update the configuration of the whole network that it should correspond to the new default gateway. For example, you might need to update the IP address settings of the switches, DHCP server, etc.
DaneA
NETGEAR Community Team
