bkosick
Jan 27, 2021Aspirant
Connect newly orderd MS510TXUP to existing GS728TP via SFP?
Hi All, I just ordered the MS510TXUP and have an existing GS728TP I'd like to link them together via SFP.. I'm assuming that the SFP on the GS 728 TP only supports 1GB, so I'd like to LAG/LACP ...
bkosick
Will the AGM731F SFP work in the MS510TXUP with the SFP slots? So for my described setup i would need
4xAGM731F
2xMultimode Duplex LC/PC patch cables...
schumaku
Jan 28, 2021Guru - Experienced User
Correct.
The MS510TXUP (and most other devices/switches SFP+) are 1G/10G SFP+ Fiber Ports. because fiber connections do not have any kind of handshake, typical 10G modules can't link up to 1G modules.
