njguitarman
Mar 02, 2019Aspirant
Connecting 2 JGS524Ev2 Smart Switches over single cable - with mirror port to work across both units
Hello. I have 2 JGS524Ev2 switches on separate floors, with 1 cable.
I also have this unit: https://www.dualcomm.com/collections/network-tap/products/gigabit-copper-network-tap, which sits bet...
- Mar 03, 2019
Please read this thread. This will not work since the switch does not support RSPAN.
RSPAN allows you to monitor traffic from source ports distributed over multiple switches, which means that you can centralize your network capture devices.
njguitarman
Diagram of desired configuration.
- Nodism1125Mar 03, 2019NETGEAR Expert
You need to setup port mirroring tper switches. The computer connected to SW2 with packet sniffer can see source ports of SW2 not SW1.
JGS524Ev2 is a smart manage plus switch.
- schumakuMar 03, 2019Guru - Experienced User
You might want to configure a dedicated VLAN spanning both switches (tagged trunk ports), and two ports untagged for this network (one on each switch) where you connect the tap resp. the sniffer. To ensure enough bandwidth is available, a LAG for the trunk should be considered.
- njguitarmanMar 03, 2019Aspirant
Thank you for your reply. Does this mean switch on floor 0 (sniffer location) will not be able to see spanned traffic from floor 1 (source data)?
I was somehow hoping to broadcast the source data from switch 1 to switch 2, so the sniffer can see the data.
As per your network drawing, you have network tap in place, you can extend it's monitoring port over either a cable or a netowrk link, e.g. a dedicated VLAN to the sniffer device.
The switches local mirroring port capability isn't ued in your usage context at all, isn't it?
