njguitarman
Mar 03, 2019Aspirant
Connecting 2 JGS524Ev2 Smart Switches over single cable - with mirror port to work across both units
Hello. I have 2 JGS524Ev2 switches on separate floors, with 1 cable.
I also have this unit: https://www.dualcomm.com/collections/network-tap/products/gigabit-copper-network-tap, which sits bet...
- Mar 03, 2019
Please read this thread. This will not work since the switch does not support RSPAN.
RSPAN allows you to monitor traffic from source ports distributed over multiple switches, which means that you can centralize your network capture devices.
Nodism1125
Mar 03, 2019NETGEAR Expert
njguitarman
okay. thank you for providing access to that thread. I guess case closed, unfortunately :-(
Thank you!
