vaiku007
Sep 07, 2021Follower
Connecting Netgera GS724tpv2 to s cisco 2960 uplink
Hello , I am trying to connect a GS724tpv2 to s cisco 2960 switch. I am unable to I create vlan on the GS724tpv2 and pass the vlan as access then as trunk from cisco side The port on GS724tpv2 wo...
JohnC_V
Sep 08, 2021NETGEAR Employee Retired
Welcome to our community! :)
In order for you to connect this switch to another switch will be depending on your setup. If you are using VLANs from the cisco switch, you may need to assign the uplink port of the NETGEAR switch to T or Tagged and make sure that the cisco switch is also assigned as a trunk port.
John
NETGEAR Community Team
