josiasmor
Nov 03, 2019Aspirant
Connecting non-poe device to Poe connector
Are ALL Netgear poe switches compatible with non poe devices? In other words: if I have a Netgear switch poe, could I connect any non-poe device safely? Thank you
- Nov 03, 2019
Yes, PoE delivery is triggered by a negotiation between the Power Sourcing Equipment (PSE) and the PD (powered device). The latest standards use LLDP in addition. If nothing is negotiated, there is no power supplied.
schumaku
Nov 03, 2019Guru - Experienced User
