0bones's avatar
0bones
Follower
Nov 01, 2016
connecting two GS116Ev2 with LAG
I have now one GS116Ev2 device. I need more ports to connect to, so the question is can I connect two models of GS116Ev2 with a 4 port LAG or is there an other option how to connect the devices? Or should I buy a 24 port model. What is technically the best?
For the connection of my NAS I have already configured a 4 port LAG. Can the switch manage 2 4 port LAGs?
Thanks for the answers.
  • Hi 0bones,
    Welcome to the community! :)
    GS116Ev2 is only capable of static LAGs.  You can configure 8 static LAGs with 2 to 4 static LAG members on this switch.  Kindly check pages 2 and 6 of the data sheet here as reference.
    You may want to consider using NETGEAR Smart switch models (like the GS108Tv2 or GS110TP) instead of the GS116Ev2 (which is a NETGEAR ProSAFE Plus switch model).  Its because, it is more recommended to configure LACP instead of static LAG between a switch and a NAS.
    Check this link for standalone smart switch models.  Consider the smart switch models having a "GS" prefix because that denotes that it is Gigabit Switch.
    DaneA
    NETGEAR Community Team
1 Reply
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi 0bones,
    DaneA
ProSupport for Business
