z_ae19844's avatar
z_ae19844
Follower
Sep 24, 2023
Connectivity and bandwidth re: Pro GS108T-300UKS managed switch
Hi all,
Trying to help a customer get connected up. They are using a Cityfibre FTTP connection via Zen Internet, and they are using a Google Mesh router. Unfortunately, the router is not compatible when it gets plugged into the ONT, it will not support VLAN911 as confirmed by Google.
To that end, I have found a small managed switch (Pro GS108T-300UKS) which I think may be able to bridge 2 ports and allow traffic to flow, and the customer's router to authenticate with the ISP's RADIUS.
My questions are:
Is the switch rated to a gigabit in terms of network throughput, or less?
Has anyone carried out a similar task and if so, is there any guidance to corroborate what we are trying to do?
Thank you
1 Reply
  • schumaku's avatar
    schumaku
    Of course, these switches are providing fully line speed, the switch fabric does provide a 16 Gbps line-rate, covering bi-directional wire speed on all ports.
    Performance Specifications GS108Tv3
    1G Copper latency (µsec)
    (64-byte; 1518-byte; 9216-byte frames)
    64-byte: 3.847 µsec
    1518-bye: 4.047 µsec
    9216-byte: 3.784 µsec
ProSupport for Business
