scottstgelais
Jun 28, 2021Follower
Cooling fans running fast
The cooling fans inside of our Netgear S3300-52X-PoE+ ProSAFE 48-Port Gigabit Stackable Smart Switch with PoE+ and 4 10G uplinks randomly start spinning really fast. The tempature where the switch is...
DaneA
Jun 29, 2021NETGEAR Employee Retired
Welcome to the community! :)
Kindly update the firmware of your S3300-52X-PoE+ switch to the latest version which is v6.6.4.25 then observe if the same problem will occur. You can download S3300-52X-PoE+ FW v6.6.4.25 here.
DaneA
NETGEAR Community Team
