Etz
May 02, 2018Aspirant
Couple of questions about GS110EMX
1) Does GS110EMX support SNMP?
2) What does Web Managed mean, Web Interface or only restricted to config utility?
HI Etz
The GS110EMX doesn´t support SNMP, about the management it´s web managed so you can configure using your browser . Moreover you also can configure it using the Prosafe Plus utility if you prefer.
Hope it helps!
Xavier Lleixa
NETGEAR CBU PLM
