bigdaveXL
Jan 28, 2020Tutor
Create Vlan on GS724Tv4
I currently have two VLans that are both set with the same IP addresses (all 192.168.0.x) I have no duplicate IP addresses within this as on Vlan A the DHCP is set to give IP's 192.168.0.2-50 and on Vlan B they are 192.168.0.51-100. This works in so far as VLAN A cannot see VLAN B. However I now have a requirement whereby there is a subset of clients on VLAN A (192.168.0.5-10) that VLAN B need to see. I have been informed my VLANS are setup wrong and they should both be on different IP ranges. Is this the case? if so I can reconfigure the IP's on VLAN B, but how do I then create a VLAN whereby only certain devices from A can be seen by B?
Thanks.
D.
Enable VLAN Routing (p.152) , keep the CCTV system on one untagged VLAN port, and then think about either properly limiting the access to the CCTV system, or set-up some ACLs or better IP rules (p.215/216) (that would be a longer story then).
That's not a VLAN thing at all: For IP routing, you need IP addresses ffrom different IP subnetworks.
I am not sure what you mean?
Basics of IPv4 and IPv6 routing. A router must have unique, non-overlapping IPv4 (also IPv6) subnets on the routing interfaces. You seem to have (exact information missing) 192.168.0.0/24 or so on both networks. A router can't do any routing like that.
In some large scale business migration plans, one might introduce some massive IP NAT in this case. The "other" network with 192.168.0.0/24 would appear as a different subnet, e.g. 192.168.1.0/24. But that's ways beyond of a simple L2+ switch capabilities.
In smaller network environments, there is no other choice than renumbering one of the IP networks. Even then: Not all "nice" services like device discovery (Bonjour, UPnP SSDP) will be transparent between the networks.
