mdd397
Jun 30, 2021Aspirant
DC Power question for GS305EP
Can I hook my GS305EP to DC power? If so, what are the specs I need to hook it up?
michaelkenward
Jul 01, 2021Guru - Experienced User
The GS305EP is a switch. You have posted your message in the section of this community given over to Mobile Routers, Hotspots & Modems. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so there may be useful responses here, but switches are nothing like Mobile Routers, so you might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Switches - NETGEAR Communities
or here
Smart / Plus / Click Switches - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
- schumakuJul 01, 2021Guru - Experienced User
Answered (I think) on GS305EP Power (same section now). A moderator is kindly asked to close this thread.
