MikeH701
Mar 10, 2022Aspirant
Dead ProSAFE Plus 24 Port Switch with PoE (JGS524PE)
This switch stopped working and has a limited lifetime warranty but when I try to open a support case it says, "The chat queue is busy right now. Try again soon." What good does it do to have this if...
MikeH701
Phone support is not an option. Chat is the only option.
MikeH701
When I do the "Request a Hardware Replacement" it says "Something went wrong. Please try again later"
- schumakuMar 10, 2022Guru - Experienced User
ChristineT - need your assistance here. Several similar reports recently, cause unknown (location? language? data?)
- ChristineTMar 10, 2022NETGEAR Employee Retired
schumaku ~ Thanks for looping me in!
I've escalated the issue with the online hardware replacement process not working. We are looking into it.
I'll be back in touch once I have an update. Thank you for your patience!
Cheers,
Christine
- MikeH701Mar 11, 2022Aspirant
Hi ChristineT
Thanks for forwarding this on and I know you said you would let us know as soon as you know something but do you have any ETR. This switch is used for security cameras and ofc with the switch down so are the cameras.
Thanks
