marktpalmer
Jan 22, 2017Aspirant
Default SNMP v1/v2 returns after new config loaded or reboot
Confrimed on GS108Tv2 Software 5.4.2.19, 5.4.2.22 & 5.4.2.25 Issue - Default SNMP v1/v2 settings return after uploading a canned config that does not have the default SNMP v1/v2 settings. When ...
- Jan 24, 2017
Thank you for the updates. I have inquired your concern to a higher tier of NETGEAR Support and it was suggested that you open an online case with NETGEAR Support for a deeper investigation.
DaneA
NETGEAR Community Team
marktpalmer
Jan 23, 2017Aspirant
I reviewed the fleet of switches I manage and have discovered GS716Tv2 switches have this same situation (deleting factory default SNMP community configurations does not really delete them since the configurations return after the switch is rebooted).
These models are confirmed to not have this situation:
GS724Tv4
GS748Tv5
HTH.
DaneA
Jan 24, 2017NETGEAR Employee Retired
DaneA
