Jilljoll
Apr 06, 2017Follower
Device view not working! Java not supported anymore
Hi, I can't re-enable a port on my GS108Tv2 because the Device View tab requires Java and Java applets are not supported by any browser anymore (I'm on a Mac, and Safari, Chrome, and Firefox all no ...
- Apr 11, 2017
Hi Jilljoll,
Welcome to the community! :)
To disable / re-enable a port on the GS108Tv2, kindly try the steps below:
1. On the web-GUI, go to Switching > Ports > Port Configuration.
2. Check the box next to the port to configure.
3. On the Admin Mode column, select Disable then click Apply.
4. Check again the same box next to the port to configure.
5. On the Admin Mode column, select Enable then click Apply. This will re-enable the port.
Kindly read pages 3-1 to 3-3 of the GS108Tv2 user manual here as reference guide.
Hope it helps.
DaneA
NETGEAR Community Team
DaneA
Apr 11, 2017NETGEAR Employee Retired
Hi Jilljoll,
Hope it helps.
DaneA
