rand__
Nov 01, 2017Aspirant
DHCP not traversing switch Part 2
Hi, Unfortunatly I have a follow up issue to my last issue here. This time however only the Netgear is involved. I have performed various tests already and it boild down to that the S3300 does n...
- Nov 07, 2017
Hey,
I missed a line in the config. You have DHCP snooping turned on it seems. Can we turn that off?
System > Services > Global Configuration > Turn it off
Cheers
rand__
Nov 07, 2017Aspirant
Nope :(
0x4e470x010x00S3300 6.6.4.7 0x000000000x00000000000000 ! The line above is the NSDP Text Configuration header. DO NOT EDIT THIS HEADER !Current Configuration: ! !System Description "S3300-28X-PoE+ ProSAFE 24-Port Gigabit Stackable Smart Switch with PoE+ and 4 10G uplinks" !System Software Version "6.6.4.7" !System Up Time "2 days 22 hrs 35 mins 8 secs" !Additional Packages QOS,IPv6 Management,Stacking,Routing !Current SNTP Synchronized Time: Nov 7 13:20:52 2017 UTC ! network protocol none network parms 192.168.35.248 255.255.252.0 192.168.34.1 boot auto-copy-sw vlan database vlan 2,4-10,18-19 vlan name 2 "removed" vlan name 4 "removed" vlan name 5 "removed" vlan name 6 "removed" vlan name 7 "removed" vlan name 8 "removed" vlan name 9 "removed" vlan name 10 "removed" vlan name 18 "removed" vlan name 19 "removed" exit configure sntp client mode unicast sntp server "192.168.34.2" sntp server "192.168.34.1" clock summer-time recurring EU offset 60 zone "CET" stack member 1 2 member 2 2 exit no ip domain lookup slot 1/0 2 set slot power 1/0 no set slot disable 1/0 slot 2/0 2 set slot power 2/0 no set slot disable 2/0 username "admin" password removed level 15 encrypted line console serial timeout 0 exit line telnet exit spanning-tree mst priority 0 0 snmp-server sysname "S3300Stack" ! snmp-server community "removed" snmp-server community ipaddr 192.168.34.0 removed snmp-server community ipmask 255.255.252.0 removed no set igmp header-validation ip dhcp snooping vlan 1 no ip dhcp snooping verify mac-address no ipv6 dhcp snooping verify mac-address classofservice trust untrusted interface 1/g1 description 'removed' spanning-tree bpduflood spanning-tree mst 0 cost 20000 green-mode energy-detect green-mode eee lldp notification exit interface 1/g2 description 'removed' spanning-tree bpduflood spanning-tree mst 0 cost 2000000 green-mode energy-detect green-mode eee lldp notification exit interface 1/g3 description 'removed' spanning-tree bpduflood green-mode energy-detect green-mode eee lldp notification exit interface 1/g4 description 'removed' spanning-tree bpduflood green-mode energy-detect green-mode eee lldp notification exit interface 1/g5 spanning-tree bpduflood green-mode energy-detect green-mode eee lldp notification exit interface 1/g6 spanning-tree bpduflood green-mode energy-detect green-mode eee lldp notification exit interface 1/g7 spanning-tree bpduflood green-mode energy-detect green-mode eee lldp notification exit interface 1/g8 spanning-tree bpduflood green-mode energy-detect green-mode eee lldp notification exit interface 1/g9 spanning-tree bpduflood spanning-tree mst 0 cost 20000 green-mode energy-detect green-mode eee lldp notification exit interface 1/g10 spanning-tree bpduflood green-mode energy-detect green-mode eee lldp notification exit interface 1/g11 spanning-tree bpduflood spanning-tree mst 0 cost 20000 green-mode energy-detect green-mode eee lldp notification exit interface 1/g12 spanning-tree bpduflood green-mode energy-detect green-mode eee lldp notification exit interface 1/g13 description 'removed' spanning-tree bpduflood green-mode energy-detect green-mode eee lldp notification exit interface 1/g14 spanning-tree bpduflood green-mode energy-detect green-mode eee lldp notification exit interface 1/g15 description 'removed' spanning-tree bpduflood spanning-tree mst 0 cost 20000 green-mode energy-detect green-mode eee lldp notification exit interface 1/g16 spanning-tree bpduflood spanning-tree mst 0 cost 200000 green-mode energy-detect green-mode eee lldp notification exit interface 1/g17 spanning-tree bpduflood green-mode energy-detect green-mode eee lldp notification exit interface 1/g18 description 'removed' spanning-tree bpduflood green-mode energy-detect green-mode eee lldp notification exit interface 1/g19 spanning-tree bpduflood green-mode energy-detect green-mode eee lldp notification exit interface 1/g20 spanning-tree bpduflood green-mode energy-detect green-mode eee lldp notification exit interface 1/g21 description 'removed' spanning-tree bpduflood spanning-tree mst 0 cost 20000 vlan pvid 2 vlan participation auto 1 vlan participation include 2 green-mode energy-detect green-mode eee lldp notification exit interface 1/g22 description 'removed' spanning-tree bpduflood spanning-tree mst 0 cost 2000000 vlan pvid 2 vlan participation auto 1 vlan participation include 2 green-mode energy-detect green-mode eee lldp notification exit interface 1/g23 description 'removed' spanning-tree bpduflood vlan pvid 2 vlan participation auto 1 vlan participation include 2 green-mode energy-detect green-mode eee lldp notification exit interface 1/g24 description 'removed' spanning-tree bpduflood vlan pvid 2 vlan participation auto 1 vlan participation include 2 green-mode energy-detect green-mode eee lldp notification exit interface 1/xg25 description 'removed' spanning-tree bpduflood mtu 9198 vlan tagging 1 green-mode eee lldp notification exit interface 1/xg26 spanning-tree bpduflood mtu 9198 vlan participation include 5-10,18-19 vlan tagging 1,5-10,18-19 green-mode eee lldp notification exit interface 1/xg27 description 'removed' spanning-tree bpduflood spanning-tree mst 0 cost 2000 mtu 9198 vlan participation include 5-10,18-19 vlan tagging 1,5-10,18-19 lldp notification exit interface 1/xg28 spanning-tree bpduflood mtu 9198 lldp notification exit interface 2/g1 description 'removed' spanning-tree bpduflood green-mode energy-detect green-mode eee lldp notification exit interface 2/g2 description 'removed' spanning-tree bpduflood spanning-tree mst 0 cost 20000 green-mode energy-detect green-mode eee lldp notification exit interface 2/g3 description 'removed' spanning-tree bpduflood vlan pvid 2 vlan participation auto 1 vlan participation include 2 green-mode energy-detect green-mode eee lldp notification exit interface 2/g4 description 'removed' spanning-tree bpduflood spanning-tree mst 0 cost 200000 vlan pvid 2 vlan participation auto 1 vlan participation include 2 green-mode energy-detect green-mode eee lldp notification exit interface 2/g5 description 'removed' spanning-tree bpduflood green-mode energy-detect green-mode eee lldp notification exit interface 2/g6 description 'removed' spanning-tree bpduflood green-mode energy-detect green-mode eee lldp notification exit interface 2/g7 spanning-tree bpduflood green-mode energy-detect green-mode eee lldp notification exit interface 2/g8 spanning-tree bpduflood green-mode energy-detect green-mode eee lldp notification exit interface 2/g9 description 'removed' spanning-tree bpduflood spanning-tree mst 0 cost 20000 vlan participation include 2 green-mode energy-detect green-mode eee lldp notification exit interface 2/g10 spanning-tree bpduflood green-mode energy-detect green-mode eee lldp notification exit interface 2/g11 spanning-tree bpduflood green-mode energy-detect green-mode eee lldp notification exit interface 2/g12 spanning-tree bpduflood green-mode energy-detect lldp notification exit interface 2/g13 spanning-tree bpduflood spanning-tree mst 0 cost 20000 green-mode energy-detect green-mode eee lldp notification exit interface 2/g14 spanning-tree bpduflood spanning-tree mst 0 cost 20000 green-mode energy-detect green-mode eee lldp notification exit interface 2/g15 spanning-tree bpduflood spanning-tree mst 0 cost 20000 green-mode energy-detect green-mode eee lldp notification exit interface 2/g16 spanning-tree bpduflood spanning-tree mst 0 cost 20000 green-mode energy-detect green-mode eee lldp notification exit interface 2/g17 spanning-tree bpduflood spanning-tree mst 0 cost 2000000 green-mode energy-detect green-mode eee lldp notification exit interface 2/g18 spanning-tree bpduflood spanning-tree mst 0 cost 20000 green-mode energy-detect green-mode eee lldp notification exit interface 2/g19 spanning-tree bpduflood spanning-tree mst 0 cost 2000000 green-mode energy-detect green-mode eee lldp notification exit interface 2/g20 spanning-tree bpduflood green-mode energy-detect green-mode eee lldp notification exit interface 2/g21 spanning-tree bpduflood spanning-tree mst 0 cost 20000 green-mode energy-detect green-mode eee lldp notification exit interface 2/g22 spanning-tree bpduflood green-mode energy-detect green-mode eee lldp notification exit interface 2/g23 description 'removed' spanning-tree bpduflood spanning-tree mst 0 cost 20000 vlan pvid 2 vlan participation auto 1 vlan participation include 2 green-mode energy-detect green-mode eee lldp notification exit interface 2/g24 description 'removed' spanning-tree bpduflood spanning-tree mst 0 cost 20000 vlan participation include 2 green-mode energy-detect green-mode eee lldp notification exit interface 2/xg25 description 'removed' spanning-tree bpduflood spanning-tree mst 0 cost 200000 mtu 9198 vlan ingressfilter vlan participation include 5-10,18-19 vlan tagging 5-10,18-19 green-mode eee lldp notification exit interface 2/xg26 description 'removed' spanning-tree bpduflood mtu 9198 vlan tagging 1 green-mode eee lldp notification exit interface 2/xg27 description 'removed' spanning-tree bpduflood mtu 9198 vlan ingressfilter vlan participation include 5-10,18-19 vlan tagging 5-10,18-19 lldp notification exit interface 2/xg28 description 'removed' spanning-tree bpduflood mtu 9198 vlan ingressfilter vlan participation include 5-10,18-19 vlan tagging 5-10,18-19 lldp notification exit interface lag 1 spanning-tree bpduflood exit interface lag 2 spanning-tree bpduflood exit interface lag 3 spanning-tree bpduflood exit interface lag 4 spanning-tree bpduflood exit interface lag 5 spanning-tree bpduflood exit interface lag 6 spanning-tree bpduflood exit interface lag 7 spanning-tree bpduflood exit interface lag 8 spanning-tree bpduflood exit interface lag 9 spanning-tree bpduflood exit interface lag 10 spanning-tree bpduflood exit interface lag 11 spanning-tree bpduflood exit interface lag 12 spanning-tree bpduflood exit interface lag 13 spanning-tree bpduflood exit interface lag 14 spanning-tree bpduflood exit interface lag 15 spanning-tree bpduflood exit interface lag 16 spanning-tree bpduflood exit interface lag 17 spanning-tree bpduflood exit interface lag 18 spanning-tree bpduflood exit interface lag 19 spanning-tree bpduflood exit interface lag 20 spanning-tree bpduflood exit interface lag 21 spanning-tree bpduflood exit interface lag 22 spanning-tree bpduflood exit interface lag 23 spanning-tree bpduflood exit interface lag 24 spanning-tree bpduflood exit interface lag 25 spanning-tree bpduflood exit interface lag 26 spanning-tree bpduflood exit no scc mode exit
Hopchen
Nov 07, 2017Prodigy
Hey,
Cheers
- rand__Nov 07, 2017Aspirant
Again, would have thought the global config setting it off would be sufficient (screenshot top line) but happy to try:)
- HopchenNov 07, 2017Prodigy
It is odd. It seems enabled in the config file.
I will PM you. I might have support look into this.
Ok, I think something helped finally, got a dhcp address from the AD server which is in a vm so it needs to pass within the switch.
Not entirely sure which change actually did it now. Might have to play with the various settings.
Will need to spin up a couple more boxes to be sure though
Edit: Yes its looking good. Currently running with a single switch since I had been preparing to split if necessary but I am full of confidence that that it will work with the full stack as well :)
Will give a final feedback then but for now looks good.
Thank you very very much !
Also, please consider marking this thread as resolved for now.
