MISSION
Oct 07, 2016Aspirant
DISABLE POE ON A PORT
Been reading the help manual and i cantfind where i can disable the POE on a single port. My port (24) connects to another switch that doesnt need POE. i have been in system/poe/poe port configu...
- Oct 09, 2016
Hi MISSION,
Welcome to NETGEAR community!
The "admin mode" of PoE is only for PoE power control not the physical link.
In other words,After you disable "admin mode" of PoE on port(24).
The port will work correct and communication with another switch with physical link without PoE function.
So you can disable it from System->PoE->PoE port configuration on your port(24) and go ahead your networking.
May the suggestion help you. :smileyhappy:
Daniel.
