DougShuffield
Mar 08, 2019Tutor
Enable / Disable POE per port via ssh / telnet
I would like to know the command sequence to enable / disable POE on a port by port basis. In the user interface this is the admin mode column. I have not been able to find a full description of the command line interface for this switch. I have successfully enabled and connected to my GS752TP via ssh and can get into config mode. From there I can list the ports with 'do show power inline' but I have not been able to determine how to enable / disable poe on a specific port.
Any help would be appreciated.
Doug
Instead of using the (unsupported, well possible incomplete, ...) CLI access use SNMP -> https://community.netgear.com/t5/Smart-Plus-Click-Switches/Switch-GS728TP-POE-Admin-enable-disable-via-SNMP/m-p/1574183/highlight/true#M9657
The GS727TP is a Smart Managed Pro switch, not a Managed Switch -> Smart / Plus / Click Switches (easy to overlook on the brilliantly bad community structure ChristineT Christian_R )
1 Reply
