FishEyeGuy
Oct 04, 2017Tutor
Do I need extra SW to use TFTP upload/download on Windows 10
I'd like to use the TFTP Upload and Download interface on my company's Netgear GS724Tv4 Smart Switch. I'm using a Windows 10 PC connected directly to the switch. I've been able to use the HTTP u...
- Oct 13, 2017
Hi DaneA,
After some research and some digging around on the PC, I figured out that the firewall was blocking the TFTP port. After allowing Inbound and Outbound UDP for the TFTP port, I was able to get the TFTP server to work.
FishEyeGuy
JohnC_V
Oct 05, 2017NETGEAR Employee Retired
Hi FishEyeGuy,
We have been using TFTP32 for uploading and downloading files in our switches. Tech support file shows configuration as well as crashes and other logs. TFTP upload only supports specific log files.
- FishEyeGuyOct 05, 2017Tutor
Thanks, JohnCarloV.
I tried the SolarWinds TFTP server with no luck. I tried with the web service and using the command line interface. A check of the logs showed that the TFTP client on the switch timed out.
I'll give TFTP32 a try.
FishEyeGuy
- JohnC_VOct 05, 2017NETGEAR Employee Retired
- FishEyeGuyOct 13, 2017Tutor
Hi DaneA,
FishEyeGuy
