FishEyeGuy
Oct 04, 2017Tutor
Do I need extra SW to use TFTP upload/download on Windows 10
I'd like to use the TFTP Upload and Download interface on my company's Netgear GS724Tv4 Smart Switch. I'm using a Windows 10 PC connected directly to the switch. I've been able to use the HTTP u...
- Oct 13, 2017
Hi DaneA,
After some research and some digging around on the PC, I figured out that the firewall was blocking the TFTP port. After allowing Inbound and Outbound UDP for the TFTP port, I was able to get the TFTP server to work.
FishEyeGuy
FishEyeGuy
Oct 05, 2017Tutor
Thanks, JohnCarloV.
I tried the SolarWinds TFTP server with no luck. I tried with the web service and using the command line interface. A check of the logs showed that the TFTP client on the switch timed out.
I'll give TFTP32 a try.
FishEyeGuy
JohnC_V
Oct 05, 2017NETGEAR Employee Retired
- FishEyeGuyOct 13, 2017Tutor
Hi DaneA,
FishEyeGuy
- JohnC_VOct 13, 2017NETGEAR Employee Retired
