jerry2096's avatar
jerry2096
Does gs switch support trunk port
As subject - does it support Trunk port?
If not, which Netgear model support it? For home lab.
thanks
  • I mean, set up one port for trunk port, but have multiple vlan trunked with just 1 port.
  • schumaku's avatar
    schumaku
    Yes, of course. The VLAN must be defined first, then you can e.g. create a trunk port (similar also a trunk LAG) for participating untagged in only one VLAN (VLAN x [u]ntagged, PVID 1, and multiple tagged VLAN (VLAN y [t]agged, VLAN z [t]agged.
ProSupport for Business
