vickylingtw
Nov 07, 2021Aspirant
Does Netgear have a 8 port PoE extender/passthrough?
I have a GS108Tv2 powered by GS305P. I've only found the 5 port GS105PE. However, I ask because D-Link apparently has an 8 port PoE DGS-1100-8P Rev B that unofficially can be PoE powered through ...
vickylingtw
Thanks that's the same place I got the information from.
I really only need 3W. Unfortunately all the ports are wired to a switch inside a box with no outlets, so it's PoE powered.
schumaku
Nov 08, 2021Guru - Experienced User
Well, if these PDs are following the IEEE PoE standards and request Class 1 (which requires the allocation of 4.4W at the PSE per port), being by the classic PoE scheme or by LLDP Power via MDI TLV IEEE 802.3-2015 - permitting the prospec PoE switch can handle it - you might have the chance to drive about four PDs under these conditons.
- Sep 11, 2022Retired_Member
