N0X
Apr 04, 2022Aspirant
Doubt about VLAN
Greetings, I have a small network at home that is composed (in short) by a Mikrotik routerboard and two switches, the main TP-Link and the secondary AlliedTelesis. I have multiple VLANs going through...
schumaku
Apr 04, 2022Guru - Experienced User
@N100X wrote:
All the VLANs work fine with the exception of VLAN 1 which does not reach the routerboard.
So there is something wrong with the trunk and port config for tagged vs untagged.
N0X wrote:
In the Netgear switch, change the administrative VLAN to 5 and it reaches the routerboar but through 1 it does not.
This does not change anything on the VLAN config, just the admin features (management IP, WebUI, SNMP, telnet, SSH, is relocated.) Completely unrelated.
- N0XApr 08, 2022Aspirant
All vlans arrive at the routerboard through the trunk port, except vlan 1. If I try to access vlan1 through another untagged port, I can access it.- schumakuApr 17, 2022Guru - Experienced UserAnd how is the VLAN 1 configured on the trunk port and the router board? By default, the VLAN 1 is preconfigured on all ports as untagged and that's the reason why it's set to PVID 1 to associate untagged incoming frames to be VLAN 1.
- N0XApr 17, 2022Aspirant
in the router to the port where the switch is connected, create a vlan with the id 1. looking at the vlan configuration of the netgear switch, being vlan 1 by default it does not let me assign the trunk port, could this be the problem?
