N0X
Apr 04, 2022Aspirant
Doubt about VLAN
Greetings, I have a small network at home that is composed (in short) by a Mikrotik routerboard and two switches, the main TP-Link and the secondary AlliedTelesis. I have multiple VLANs going through...
schumaku
Apr 04, 2022Guru - Experienced User
@N100X wrote:
All the VLANs work fine with the exception of VLAN 1 which does not reach the routerboard.
So there is something wrong with the trunk and port config for tagged vs untagged.
N0X wrote:
In the Netgear switch, change the administrative VLAN to 5 and it reaches the routerboar but through 1 it does not.
This does not change anything on the VLAN config, just the admin features (management IP, WebUI, SNMP, telnet, SSH, is relocated.) Completely unrelated.
N0X
Apr 08, 2022Aspirant
All vlans arrive at the routerboard through the trunk port, except vlan 1. If I try to access vlan1 through another untagged port, I can access it.- schumakuApr 17, 2022Guru - Experienced UserAnd how is the VLAN 1 configured on the trunk port and the router board? By default, the VLAN 1 is preconfigured on all ports as untagged and that's the reason why it's set to PVID 1 to associate untagged incoming frames to be VLAN 1.
- N0XApr 17, 2022Aspirant
in the router to the port where the switch is connected, create a vlan with the id 1. looking at the vlan configuration of the netgear switch, being vlan 1 by default it does not let me assign the trunk port, could this be the problem?
- schumakuApr 17, 2022Guru - Experienced UserThe Untagged port(s), specifically the one in use for the trunk, can't be changed to Tagged?
