Chaos215bar2
Feb 23, 2021Tutor
Error accessing registration server?
After configuring a couple GS105PE switches, I'm receiving an error stating "An error occurred while accessing the NETGEAR registration server. Check your Internet connection, and then try again." ab...
schumaku
Mar 03, 2021Guru - Experienced User
The Smart Managed Plus switches don't require or enforce a registration, indeed. Out of the box, or following a factory reset, there is a pop-up suggesting the product registration - and this comes with an option for a [x] tick to never show up again.
The switch on it's own does not call home. It's the Web UI checking the registration server for the registration status in the background however regardless of the above. Appears there was a problem with the registration server few days ago, so this "Error accessing registration server" showed up.
apsis0215
Mar 13, 2021Aspirant
Same issue
Alert
Registration
And the "Plus" they are selling no longer works with windows 10 because adobe air and PKAp or some such install doesn't work.
What the hell netgear?
