CompEng
Jan 13, 2025Aspirant
Every Monday Morning Ethernet Goes Down
Every Monday morning, my ethernet goes out on all my PC's. The wifi remains but land lines are dead. So, my set up is Modem --> Router (Netgear RS500) -->Ethernet switch (Netgear GS105) --> Switch (Linksys). This problem has only been happening since I got a new modem from Spectrum about 5 weeks ago. So that would seem to be the issue. But if I unplug the switches from the router, all of the ethernet ports then work great. Sounds like addressing or loopback, but if I unplug everything then start over with one thing at a time going back in...all is well. And will stay that way until the next Monday morning then it crashes all over again. I'm a computer Engineer but a hardware design guy. I know enough about internet connectivity to be dangerous but admit this problem is baffling me although it seems simple why is it happening only every Monday? Thanks in advance. đ
what modem did they install?
What linksys switch is it?
Does it matter if its only the linksys plugged in or just the netgear?
How is everything wired up?
- CompEngAspirant
Modem is
Spectrum E31U2V1 DOC SIS 3.1 Internet Cable Modem, Linksys router is se3008.
The setup goes from modem to router...from router (2 pc's connected directly to router) then a third out to netgear switch in the basement, then output from netgear switch to 1 pc and another output to linkysys router..from linksys router it feed two computers for the wife's business. I have just begun to isolate the switches but not on a Sunday night to see which one if any will cause the issue. I'll do that this week. In the meantime I was hoping to get an idea of what the issue may be if anyone knew?
- CompEngAspirant
Side note: If I unplug the ethernet lines from the router that feed the switches, the two computers connected to the router come online. So I know it's about the switches, just not sure what it is.
