db-user
Aug 08, 2017Aspirant
Execution order when binding multiple IP ACL tables
Model : GS108T managed switch From your excellent manual, I understand that there is an implicit "Deny All" ACL rule at the end of an IP ACL table. When binding multiple IP ACL tables (say, A...
- Aug 08, 2017
Hi,
I assume you are making two different ACL tables? One table called: "ACL ID1" and one called "ACL ID2"? Or are you referring to two ACL rules, inside the same table?
Assuming that you are talking about two different tables and how to bind those to a single port:
1. You need bind the first table and give that sequence number: 1. Then bind the second table to the same port, but bind with sequence number: 2. What this will do is read all the ACLs in table 1 and the continue on to the rules in table 2 - as if they were one big table.
2. If you want several ACL tables to be executed, one after the other, then you only put a "Permit All" at the bottom of the last ACL table.
3. If no condition is meet in the last ACL table ("ACL ID2" in your case), then the implicit "Deny All" will be executed. Hence why you should set the "Permit All" as the last rule of the last table in the sequence.
I hope this helped. Cheers
