sinman's avatar
sinman
fvs336gv3 protocol binding
Hi
I have a dual wan set up
WAN1 - Leased line for VoIP
WAN2 - ADSL for all other traffic (has high latency)
We have configured Weighted LB, Protocol binding of all SIP traffic to go to WAN1. HTTP/S to WAN2.
QoS is enabled for the SIP traffic to high.
The problem I have is that I ideally need ALL traffic to go through WAN2 except for VoIP which will be set to WAN1 as calls seem to drop 80% of the time if they go via the ADSL link.
I can't see how I can configure this as even with the above, I am still seeing the VoIP traffic routing through WAN2 far too often.
Thanks for any help
  • Hi sinman,
    Welcome to the community! :)
    Let us try this:  kindly remove the protocol binding for the VoIP that is configured then just define an outbound policy for it in the firewall rules and observe.
    What is the current firmware version of the FVS336Gv3?
    DaneA
    NETGEAR Community Team
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi sinman,
    DaneA
    • sinman's avatar
      sinman
      Hi DaneA
      Thanks for the welcome :-)
      Am I correct in thinking that the WAN users IP is the destination (SIP server) and the NAT IP should be the WAN connection I want it routed via (WAN1)?
      I will give this a shot and report back
      Firmware is: 4.3.3-6
      Thank you for your help, I really appreciate it
      Thanks
      Simon
      • DaneA's avatar
        DaneA
        @sinman,
        I just want to follow-up.  Were you able to try my suggestion?  If yes, what is the result?
        Also, I suggest that you to upgrade the firmware of the FVS336Gv3 to v4.3.5-3 then perform a factory reset on it.  Afterwards, reconfigure it from scratch in order to start clean using the latest firmware version.  You may download firmware v4.3.5-3 here.
        DaneA
ProSupport for Business
