jasonh148
Jun 22, 2021Aspirant
Failover link between two GS728TPs
I have two GS728 switches in different buildings. There are two links between the buildings; a point-to-point wireless and a fibre. I would like to have both connected to the switches and have the sw...
schumaku
Jun 23, 2021Guru - Experienced User
Afraid, LACP is to aggregate two or more links with the same link sped and latency only.
STP, much more RSTP, is your friend for such a config.
- jasonh148Jun 23, 2021Aspirant
Good to know, thanks!
For RSTP, how do I tell it which port is primary/secondary? CST Configuration settings, set the port priority?
- schumakuJun 24, 2021Guru - Experienced User
In STP and RSTP, it's about the interface path cost. The cost prioritizes routing to the destination. The lower the cost, the higher the priority.
