jasonh148
Jun 22, 2021Aspirant
Failover link between two GS728TPs
I have two GS728 switches in different buildings. There are two links between the buildings; a point-to-point wireless and a fibre. I would like to have both connected to the switches and have the sw...
jasonh148
Jun 23, 2021Aspirant
Good to know, thanks!
For RSTP, how do I tell it which port is primary/secondary? CST Configuration settings, set the port priority?
schumaku
Jun 24, 2021Guru - Experienced User
In STP and RSTP, it's about the interface path cost. The cost prioritizes routing to the destination. The lower the cost, the higher the priority.
