KevinB15's avatar
KevinB15
Fiber Connection
Have a GS752TXS w/ 4 10G fiber connections and a GS728TX-100NES w/ 2 10G fiber connections,  both using AXM761 modules.   On the GS752, port 49 is connected to a NAS, port 50 is connected to a server.   When I connect the GS728 to port 51, the link led's will light up, nothing connected to it can see anything from the GS752.   Any help will be appreciated.
  • Carl_z's avatar
    Carl_z
    Apr 04, 2017
    Hi KevinB15,
    It very helpfull about the provided information.
    On GS752TXS Port 51,52 are stack ports. So they can't be used for ethernet connection.
    We need to change port 51,52 from stack mode to ethernet mode with following steps.
    1.Go to  "System /Stacking/Stack Port Configuration"
    2.Select port 51/52.
    3.Change configured stack mode to Ethernet.
    4.Click Apply on the right bottom。
    5.Restart the switch.
    Hope it helps
    Best Regards
    Carl
  • Carl_z's avatar
    Carl_z
    NETGEAR Expert
    Hi KevinB15,
    Welcome to the community!
    Can you help to share the following information
    Ports status about GS752TXS (port 49,50,51) via "Switching /Ports"
    Ports PVID status about GS752TXS  and GS728TX via "Switching/Vlan/Advanced/Port pvid configuration "
    Regards
    Carl
    Netgear Employee
    • KevinB15's avatar
      KevinB15
            Physical Status    Link Status
      49:   10G full              Link Up
      50:   10G full              Link Up
      51:    blank                 Detach
      52:    blank                 Detach
             current PVID
      49:  1
      50:  1
      51:  0
      52:  0
        and GS728TX
             PVID
      27: 1
      28: 1
      • Carl_z's avatar
        Carl_z
        NETGEAR Expert
        Hi KevinB15,
        Hope it helps
        Best Regards
        Carl
ProSupport for Business
