hosregla
May 24, 2016Aspirant
filtering MAC by port gs748v4h2
GS748Tv4H2 B5.3.0.2 5.4.2.13 I want every port switch, operate only one MAC , I mean a PC , printer etc. I tried to do it by following these steps, but can not. https://community.netgea...
- Jun 14, 2016
Hi hosregla,
I suggest you to open an online case with NETGEAR Support at any anytime. Let them know about your concern for further assistance.
DaneA
NETGEAR Community Team
DaneA
May 24, 2016NETGEAR Employee Retired
Hi hosregla,
If you try to connect other PCs/laptops to other ports except for port 41, are you able to get a connection?
What if you try to complete the configuration by selecting the Destination Port Members as well? Check if same problem occurs. Try to reboot the switch as well.
DaneA
hosregla
Should I set destination port number somehow? As shown in the capture, I understand that with that mac pc only work in this port ?.
I apply the change and reinecio switch to take effect?
The other ports can take any MAC.
Really what I want is that every Mac, go to a specific port.
I have 5 netgear ProSafe switch.
Thks by your time. Remote is allowed ;)
- DaneAMay 25, 2016NETGEAR Employee Retired
Hi hosregla,
Yes, kindly try to set the Destination Port Members as well. If ever same problem occurs, I suggest you to upgrade the firmware to v5.4.2.18. Make sure to perform a factory reset on the GS748Tv4 after a successful firmware upgrade then reconfigure it form scratch. Check if same problem occurs. You may download firmware v5.4.2.18 here.
About the remote access, you may want to open an online case with NETGEAR Support at anytime. State your concerns and indicate the steps you've done so far to isolate the problem.
DaneA
