gtb_
Dec 05, 2022Follower
Firmware update for Netgear GS748Tv5 - Issue Firmware not supported
Trying to update the firmware for a client site with 4* 48 port Netgear GS748Tv5 switch on site. I am planning to use the SMART CONTROL CENTRE for the firmware update. Issue : at the final stage...
schumaku
Dec 06, 2022Guru - Experienced User
SCC is an obsolete legacy application, still workable however. Preferred way is upload the firmware image to one of the two available image areas, and activate it before the restart.
Double check these are GS748Tv5 (GS748T-500xxx) models. Have expanded the archive and extracted the image file gs7xxt-v6.3.1.43.stk ?
Follow the older version release notes - it's much more informative for newcomers in this task https://kb.netgear.com/000038699/GS716Tv3-GS724Tv4-GS748Tv5-Firmware-Version-6-3-1-19
PapaPeteH
May 24, 2023Guide
THANK YOU! Yes, those instructions for HTTP firmware install DO work. SCC appears to work, but in reality messes up the firmware upload as I've documented elsewhere.
