Roger_Mac
Feb 09, 2022Follower
Firmware Update
New here. Need assistance/instructions to update our switch's firmware. GS724Tv4 ProSafe 24-port Gigabit Ethernet Smart Switch, 6.3.1.19, B1.0.0.4
Feb 09, 2022Guru - Experienced User
There's a everything from guides to videos.
The support site is a good place to start.
It has the firmware, guides, manuals, etc.
https://www.netgear.com/support/product/GS724Tv4.aspx
there's videos people have made on youtube demonstrating it (not my video)
https://www.youtube.com/watch?v=jnt_L70_Vt0
- RonWLJul 05, 2022Tutor
Have tried several times to update the firmware on my GS724Tv4 using the SmartControlCenter using gs7xxt-v6.3.1.43.stk. Every time the task times out. I try running the download immediately, and also at a future time when the system is less used, but in any event the task will timeout.
Any suggestions?
- schumakuJul 05, 2022Guru - Experienced User
Use a web browser, access the switch by http://[switch-lan-ip-address/ and authenticate using the admin password.
https://www.downloads.netgear.com/files/GDC/GS716TV3/GS716Tv3_GS724Tv4_GS748Tv5_SWA_25Sept2013.pdf p.247 ff "Maintenance"
Scratch the legacy SCC utility - it does switch to some tftp upload process, and decent Windows systems might not allow this process.
