G-Max
Jun 18, 2022Tutor
FS726T not discovered with Smart Center or anything else
As per headline, I have recently bought a FS726T switch so I could build a better network but no matter what I try I can't connect to it in any way. I have tried resetting it to factory default and ...
- Jun 18, 2022
Retired_Member
Please try to understand these switch designs are old, very old. Firmware and notes date back from 2005, so the FS716Tv1 is an almost two decade old device.
FS726T Firmware Version 1.0.2 (0323)
Note: This FS726T firmware version (or any earlier version) must be upgraded using the Smartwizard Discovery utility, version 2.05.03 or earlier. After this upgrade, any version of Smartwizard Discovery utility can be used.
Fixes
1. Switch will not retain static IP after reboot.
2. Smartwizard Discovery Utility 2.05.05 cannot upgrade firmware.Installation Instructions
- Download the new firmware to a convenient place on your local system (e.g., C:\downloads\).
- Start Smartwizard Discovery utility, (included on the CD that came with your Smart Switch). If it is not installed, do so now, before continuing.
- In Smartwizard Discovery window, click Discover to find your Smart Switch. The switch will be listed in the device list table once found. (Note: Smartwizard Discovery uses broadcast packets to find Smart Switches, which means it can only find Smart Switches in the same routing domain.)
- Highlight the Smart Switch to upgrade and click Firmware Upgrade.
- Follow the screen prompts to complete the upgrade. Smartwizard Discovery will report a successful completion at the end.
Published: April 21, 2005Document Type:
Downloads > Driver/Software/FirmwarePublished 10/12/2008 02:38 PM | Updated 09/16/2011 03:35 AM
G-Max
Jun 19, 2022Tutor
Well, I finally got it.
Thanks for suggesting Smartwizard Discovery, that's the one that finally did discover the switch and it identifies as FS726T (no firmware)
So now I'm of to find the appropriate firmware and hopefully it works after that.
Thank you all that tried to help and got me on the right path 👍👍FS726T
schumaku
Jun 20, 2022Guru - Experienced User
Good luck, hope this isn't device with a broken bootloader and/or firmware.
