Nycorawr's avatar
Nycorawr
Follower
Sep 16, 2021
FS728TPv2 - EAP-TLS compatibility?
Hey everyone, hoping someone can help out here.
We are trying to conver this client from WPA to WPA2 Enterprise with EAP-TLS.  Certs (CA/User) are deployed via Intune, as is the Wireless config.  All of that is working fine.  They are using user-based certs for RADIUS auth.
We are running into an issue with the clients where their RADIUS/NPS requests are not hitting the NPS server.  The client has a varitety of errors:
Wireless 802.1x authentication was restarted.
Eap Information: Type 13, Vendor ID 0, Vendor Type 0, Author ID 0
Restart Reason: Msm Initiated
Restart Reason: Onex Auth Timeout
The NPS server, however, never receives these requests.  They appear to get dropped by the wireless switch.  This is a very simple network:
Client -> AP -> Wireless Switch (FS728TPv2) -> Data Switch (GS748Tv5) -> NPS Server
I want to put blame on the FS728TPv2 here as it is very, very old, and I can't find any documentation regarding EAP-TLS support (Plus it is 100mbps which I want to get rid of also).
So two questions here:
1) Am I correct in assuming the FS728TPv2 does not support EAP-TLS?
2) Am I correct in assuming the GS748Tv5 DOES support EAP-TLS?
3) In looking to replace the FS728TPv2, we are looking for something between 16-28 ports, (11 total APs, but may want room to expand later), do you have any recommendations that you can guarantee DO support EAP-TLS?
Thank you!!
1 Reply
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Nycorawr,
    Welcome to the community! :)
    The FS728TPv2 does not support EAP-TLS.  As reference, kindly check its data sheet here
    The GS748Tv5 supports TLS v1.0 but not EAP.  As reference, kindly check its data sheet here
    You may want to check the M4300 Series Switches of NETGEAR supports both EAP and TLS v2.  As reference, kindly check it data sheet here
    DaneA
    NETGEAR Community Team
ProSupport for Business
