leohamel
Apr 15, 2022Tutor
GC728XP is not working after power outage
HI all I have this GC728XP switch1, its working great except when the power goes out it will not work you can only see the led on but nothing is connected like there is no switch the log is not...
DaneA
Apr 17, 2022NETGEAR Employee Retired
Is the GC728XP directly connected to an AC power outlet?
What is the current firmware version of the GC728XP? If ever its not yet the latest version, I advise you to update it. The latest GC728XP firmware is v1.0.5.35 and you can download it here.
DaneA
NETGEAR Community Team
leohamel
Apr 19, 2022Tutor
its connected directly to power outlet yes
FW is 1.0.5.22
the thing is, this switch is connected to another switch via trunk port
when we restart them both or the power goes off for both, this switch will not connect to the trunk unless we restart it again
it could be some setting on the trunk ports?
will update the FW tonight
