pprindeville
Sep 22, 2022Guide
Generating TLS certs for GS108Tv2 from command-line
Hi, I was reading the thread GS108Tv2 HTTPS/TLS guide which unfortunately I wasn't able to reply to, but perhaps it's time for a new thread anyway. I'd like to be able to generate certs from ...
pprindeville
Sep 23, 2022Guide
taysandman Any thoughts on this, since you originally resolved the issue with XCA?
Can you send me a certificate you generated this way, that is known to work, and I'll try to figure out what command-line options are needed to reproduce it?
Thanks
