pprindeville
Sep 22, 2022Guide
Generating TLS certs for GS108Tv2 from command-line
Hi, I was reading the thread GS108Tv2 HTTPS/TLS guide which unfortunately I wasn't able to reply to, but perhaps it's time for a new thread anyway. I'd like to be able to generate certs from ...
pprindeville
Oct 06, 2022Guide
I'd like to put up a script (bash script using openssl CLI) to do this on GitHub; can someone from support reach out to me and walk me through this? My switch no longer has complimentary support...
- Retired_MemberOct 07, 2022
It looks like you need to learn more about the concept. What you have is not complete. There is a lot of information on this on Internet. Just google it. I suggest a search phrase like this: openssl create own ssl certificate authority.
- pprindevilleOct 10, 2022Guide
Retired_Member wrote:It looks like you need to learn more about the concept. What you have is not complete. There is a lot of information on this on Internet. Just google it. I suggest a search phrase like this: openssl create own ssl certificate authority.
I understand a bit about the subject. For instance, best practice as defined by the CAB Forum is a bit of a moving target, and new Extended Key Usage attributes get added from time to time. It's hard to know which snapshot in time the firmware in the gs108tv2 follows and what particulars it's expecting.
- Retired_MemberOct 10, 2022
If I read your intentions correctly, this video should help you.
https://www.youtube.com/watch?v=VH4gXcvkmOY
