CHO29
Feb 26, 2025Follower
GS 724T v3
I have installed Five switches in my network model GS724T and configuration was made as follows: 1. Vlan 115 for Multicast data - port 3 to port 12 2. Management of equipment - port 13 to port ...
schumaku
Feb 28, 2025Guru - Experienced User
What network topology you have deployed, simple daisy-chain of the switch (trunks), a basic hub-and-spoke - or what for you are so keen to configure the bridge prio?
What kind of Multicast traffic you generate there?
Some industry standard ICMP based Multicast control as in use for many Live TV or video distribution?
Probably you might habe to configure ICMP Snooping here:
