Marum's avatar
Marum
Time configuration on GS 724T V3
I try to setup the SNTP Global Configuration the following way:
1 in Time Configuration set clock source to SNTP
2 In SNTP server configuration :
   Server type :DNS
  Adress: time-f.netgear.com
  Port: 123
  Priority: 1
  Version: 4
and enter Add
3  in DNS Server configuration
    Status: Enable
    DNS server 192.168.1.1
and enter Add
Back to Tme:
Nottingchanged
Date still at 01/01/1970
Time           00:35:08
What do I do wrong?
Thanks in advance for a replay
Jan
  • Marum,
    I suggest you to update the firmware of your GS724Tv3 switch from v5.4.2.18 to v5.4.2.27.  Be sure to perform a factory reset on the GS724Tv3 then reconfigure it from scratch.  Try again to setup the SNTP Global Configuration and check the result.
    You may download the latest firmware v5.4.2.27 here.
    DaneA
    NETGEAR Community Team
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi Marum,
    Welcome to the community! :)
    Kindly answer the questions below:
    a. Is the SNTP configuration  working before?
    b. What is the current firmware version of the GS724Tv3?
    Kindly try the steps below:
    1. On the web-GUI of the GS724Tv3, go to System > Management > Time > SNTP Server Configuration.
    2. On the Server Type column, select IPv4.
    3. On the Address field, enter the LAN IP Address of your default gateway (router).
    4. Leave the Port, Priority and the Version fields on defaults.
    5. Click Add.
    Note: You may need to reboot the GS724Tv3 for the settings to apply.
    Let us know the results.
    DaneA
  • Hallo, DanaA,
    First of all thanks for the fast replay.
    The suggestion of the IP adress did not solve the problem.
     Boot Version:  B5.1.1.1
     Software version: 5.4.2.18.
    The unit is brand new strait from the box.
    The only thing changed is the Software version as i hoped this would solve the problem.
    Marum.
  • DaneA's avatar
    DaneA
    Marum,
    DaneA
    • DaneA's avatar
      DaneA
      Marum,
      Thanks for the update. I'm glad to know that updating the firmware of the GS724Tv3 switch resolved the problem.  :)
      Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
      Cheers,
      DaneA
  • DaneA,
    Updating as suggested did the trick.
    Thanks,
    Marum.
ProSupport for Business
