Marum's avatar
Marum
Time configuration on GS 724T V3
I try to setup the SNTP Global Configuration the following way: 1 in Time Configuration set clock source to SNTP 2 In SNTP server configuration :    Server type :DNS   Adress: time-f.netgear.com ...
  • DaneA's avatar
    Feb 27, 2017
    Marum,
    I suggest you to update the firmware of your GS724Tv3 switch from v5.4.2.18 to v5.4.2.27.  Be sure to perform a factory reset on the GS724Tv3 then reconfigure it from scratch.  Try again to setup the SNTP Global Configuration and check the result.
    You may download the latest firmware v5.4.2.27 here.
    DaneA
    NETGEAR Community Team
ProSupport for Business
