Marum
Feb 27, 2017Aspirant
Time configuration on GS 724T V3
I try to setup the SNTP Global Configuration the following way: 1 in Time Configuration set clock source to SNTP 2 In SNTP server configuration : Server type :DNS Adress: time-f.netgear.com ...
- Feb 27, 2017
I suggest you to update the firmware of your GS724Tv3 switch from v5.4.2.18 to v5.4.2.27. Be sure to perform a factory reset on the GS724Tv3 then reconfigure it from scratch. Try again to setup the SNTP Global Configuration and check the result.
You may download the latest firmware v5.4.2.27 here.
DaneANETGEAR Community Team
Marum
Hallo, DanaA,
First of all thanks for the fast replay.
The suggestion of the IP adress did not solve the problem.
Boot Version: B5.1.1.1
Software version: 5.4.2.18.
The unit is brand new strait from the box.
The only thing changed is the Software version as i hoped this would solve the problem.
Marum.
