Marum
Feb 27, 2017Aspirant
Time configuration on GS 724T V3
I try to setup the SNTP Global Configuration the following way: 1 in Time Configuration set clock source to SNTP 2 In SNTP server configuration : Server type :DNS Adress: time-f.netgear.com ...
- Feb 27, 2017
I suggest you to update the firmware of your GS724Tv3 switch from v5.4.2.18 to v5.4.2.27. Be sure to perform a factory reset on the GS724Tv3 then reconfigure it from scratch. Try again to setup the SNTP Global Configuration and check the result.
You may download the latest firmware v5.4.2.27 here.
DaneANETGEAR Community Team
DaneA
Feb 27, 2017NETGEAR Employee Retired
DaneA
- DaneAMar 01, 2017NETGEAR Employee Retired
Thanks for the update. I'm glad to know that updating the firmware of the GS724Tv3 switch resolved the problem. :)
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,DaneA
