anavo's avatar
anavo
Follower
Sep 08, 2017
gs105Ev2 connected on LiFePo4 up to 14V, max. voltage?
Is there any overvoltage protection on gs105Ev2? Datasheet says only 12 V @ 1,0 A
  • XavierLL's avatar
    Sep 08, 2017
    Hi Anavo,
    Our switch products are designed to be used with our current PSU, unfortunately using other Power Supplies could damage the product so we don't recommend to use a non-NETGEAR PSU.
    If you are looking for a  DC powered I would recommend to check our PoE powered switches like GS108T or GS105PE that they can be powered using a PoE injector
    Xavier Lleixa
    NETGEAR CBU PLM
    Regards
ProSupport for Business
