Chris-L's avatar
Chris-L
Follower
Aug 07, 2016
GS105eV2 Firmware Update 1.4.0.9
Hi,   can anyone help me what the new feature "Added the option to enable/disable Plus Utility Management under Web GUI." means. If i get when i enable this option it won't be possible to sue the ...
  • DaneA's avatar
    Aug 07, 2016
    Hi Chris-L,
    Welcome to the community! :)
    For me, it means that when you enable this feature then you will be able to manage the GS105Ev2 switch via the ProSAFE Plus Configuration Utility.  Otherwise, if you disable it, then you can only manage the GS105Ev2 via its web-GUI.
    I believe the improvements are mentioned on the Bug Fixes.  Check it here.
    DaneA
    NETGEAR Community Team
ProSupport for Business
