glabousky
Nov 03, 2017Aspirant
GS105Ev2 IGMP snooping
Hi everyone, I bought a few days ago a GS105Ev2 and I am facing with some troubles with IGMP snooping, here is the situation : I have a PC which will send multicast video through the switch. I ha...
- Nov 08, 2017
Hi JohnCarloV,
I just solved my problem by creating a little application on one PC.
It appeared that there was no IGMP query generator on my network (only 2 PCs and the switch), and I had confirmation by NETGEAR support that the GS105e block multicast stream when it does no receive periodically IGMP report frames when snooping (according to IGMP standard).
So in order to avoid this, I made an app which send periodically IGMP report frame for the stream I want, it seems to work now.
It will certainly be better to send an IGMP query, and let the PC automatically send his report.
Glabousky
JohnC_V
Nov 07, 2017NETGEAR Employee Retired
glabousky,
I would like to have a follow up on this thread. Just in case that your issue has already been solved, please share it here in the community so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
glabousky
Nov 08, 2017Aspirant
Hi JohnCarloV,
Glabousky
