GadgetBen
Dec 12, 2020Aspirant
GS105PE - Non-PoE device on PoE port?
Hi, I have a PoE device connected and powered by pass through (PoE PSE) on Port 1 of the GS105PE. Is it possible to connect a non-PoE device (PoE PSE) to Port 2 without risking damage the non...
michaelkenward
Dec 13, 2020Guru - Experienced User
You have posted your message in the section of this community given over to General WiFi Routers (Non-Nighthawk). (This is easily done, given Netgear's impenetrable community structure.)
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Smart / Plus / Click Switches - NETGEAR Communities
I will ask the Netgear moderator to move your message.
- GadgetBenDec 14, 2020Aspirant
