josiasmor
Nov 03, 2019Aspirant
Connecting non-poe device to Poe connector
Are ALL Netgear poe switches compatible with non poe devices?
In other words: if I have a Netgear switch poe, could I connect any non-poe device safely?
Thank you
Thank you
Yes, PoE delivery is triggered by a negotiation between the Power Sourcing Equipment (PSE) and the PD (powered device). The latest standards use LLDP in addition. If nothing is negotiated, there is no power supplied.
